It's in the FAQ. posted by Draker (Eugene, OR) on April 16, 2010 at 02:07 PM
:Timing belt :Cam seals :Crank seal(Same as cam seal) :Tensioner :VTC Springs :VTC O-rings :Water By-pass Hoses :Thermostat :Water Pump :Crankshaft spacer :Spark plugs :drive belts :Might need crankshaft sprocket depending on if you have to cut your old one off. (Mine just slid off with a pry bar) :I think that's it. :Everything is sold in kits, so you just buy the kit and install everything. I bought mine from [ HREF="http://www.conceptzperformance.com">www.conceptzperforman ce.com ] but there are other places to buy this from. :
Thanks for the parts list and a possible source! Another member said I should go for the 120K kit due to the age of the car. And what about OEM parts, a couple people told me don't trust aftermarket.
